Paging Tekmar Guru's
Jay_14
Member Posts: 39
The 365 is only compatible with RTU 305, 307, 309, 310, and 312 (see D 05 from tekmar website). These products are all obsolete and no longer sold.
Jay
Jay
I have a Tekmar 365, which I'm using for VS pump mixing control to my radiant zones. Can anyone tell me which Tekmar room temperature unit (RTU) are compatible with the 365? The spec sheet for the 365 says the RTU needs to be 2K. Tekmar data brochures say the RTU-060 works ONLY with zone control 369, and the 062 & 063 seem to be the Tekmar standard 10k sensor. I'm stumped.0 -
Tekmar 365
The Tekmar 365 can use RTU 307 or be setup for thermostats.0 -
300 series obsolete
Rick:
aren't the 300 series products obsolete? Also, for the life of me, I can't find any application data where Tekmar shows integrating thermostats directly to the 365. Can you point me somewhere that shows this? I called Tekmar this afternoon, but I got tired of waiting on hold, must have been a busy day for them.0
- 119 Geothermal
- 394 Solar
