C.I. rad plumbing
There are <i>zillions like that</i>, don`t think SC will be a prob.<BR>Once the water hits the large internal spaces within, it`ll do the same job.<BR><BR>Dave
  • C.I. rad plumbing
    I am re-installing used castiron radiators and they were all plumbed in and out of the dual ports bottom same end. Is this a good or optimal way to plumb them? The rest of the plugs are hard to remove, and I would prefer to re-install them the same way, but it seems to me the flow will tend to "short-circuit". I intend to install them using home run system with pex back to manifold in boiler room.
