kickspace heater
dave_126
dave_126 Member Posts: 2
I am installing a kickspace heater. I know i want to use monoflow tee(s?). do i put the 3/4 x 3/4 x 1/2 monoflow tee on the supply side or the return side or both? Ive seen different theories so now I am asking the pros. Thanks for the help
  • Couderay
    Couderay Member Posts: 314
    Up down or both
    If the kickspace heater is above the main one on the return is enough, below the main one on the supply and one on the return. A vent isn't a bad idea either.
  • Depending on,
    the pipe size, other radiation type, length, and circ you have, as kickspace heaters are typically high resistance, you`ll likely want to add 2 mono-flow tees(F&R) regardless of being above the main.
    Dave
