Non-adjustable stats
Anyone remember the manufacturer of those sealed, non-adjustable thermostats that come in various temperature settings? They are typically usedin a home under construction so that no one will boost the heat up to 90* and leave it there!?
Thanks in advance, Adam
  • Pinball
    Pinball Posts: 249
    "Acustat". I be;ieve their made by Honeywell. You install the "bulb" for the temp you want. If you remove it to try to bypass it, it defaults to off. There used in apt. complexes as well.
