Solaia, Biasi, Crowns low water volume boilers
Robert O'Brien
Member Posts: 3,584
of those boilers will need P/S or a LLH making the system volume a moot point
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Solaia, Biasi, Crown... low water volume boilers
Is there a need to match water volume in a boiler to the type of heat transfer application? Would a larger volume boiler work better (efficiency-wise, cycling-wise) in high water mass applications, like radiant floor? The subject boilers have low water mass and I'm considering using them in a 2000 sq ft radiant floor application. thanks0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
