3 wire zone valves
Scott Larabee
Member Posts: 27
I don't have a diagram, but I would say that if you used a relay with a set of normally open and a set of normally closed contacts (such as a Tacor sr501) you could hook the thermostat to TT, hook the common to terminal 3 hook the one that makes when it's calling to 4 no and hook the one that makes when it's satisfied to 4 nc. For the end switch, you could use the other set of contacts (5 and 6 no).
That should work with no problem, but it seems as though it would make more sense to replace the zone valve!
Scott
Scott
Does anyone have the wiring diagram to use a 2 wire thermostat, using a relay, to power an old White Rodgers
3 wire zone valve?0 -
regarding wire up of zone valve
I would change the operator head on that valve to a two wire as they don't last forever. The only quirk about this is that if you have multiple WR 3 wire zone valves the wire up can get a bit tricky. White Rodgers is notorious for a not so straight forward diagram. There web site has good documentation although but does not show the 3 wire setup w/ 2 wire stat. As other post stated, it could be easily done with a spdt relay and 2 wire stat.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
