Replacement Gas Steam Boiler
Brad White
Brad White Member Posts: 2,399
50 year old Crane coal burner.... Hey, old as I am... sheesh.
Rather than go out and buy a match-up you have a fantastic opportunity to take stock of your actual needs.
This does not seem like a very big house for that climate, is it? I mean, 60 MBH for a house that old, could be insulated and sealed to be a 35-40 MBH house by today's standards. Anyway, thought I would ask.
Assuming you are sticking with steam, see how those 60 MBH worth of radiators match an accurate heat loss calculation. If not grossly over-sized, great, size by the radiators. If they are grossly over-sized or you now have an open plan, consider reducing the number of sections to match the heat loss. A project but if you can, it will get you a smaller boiler.
I will let others make model suggestions, especially given the altitude.
-Ernie White, my Dad
  • Alex_16
    Alex_16 Member Posts: 1
    New steam boiler
    Greetings-
    It's time to replace a ~50 year old Crane coal-burning, gas-converted steam boiler. Any suggestions for a specific make or model?
    On the same line, should I install an indirect water heater, and if so, do I need to bump up the BTU/hr rating of the boiler?
    60K BTU/hr worth of radiators, n. Utah, low of -10, 4000' elev.
    Thanks!
  • Best boiler I know of
    for residential gas-fired steam, is a Smith 8 series oil-designed boiler with a factory-supplied power gas burner. This is roughly 6% more efficient on an input-to-(DOE)output basis than the typical atmospheric boiler.
    The 8 series is tapped for an indirect hookup, and you don't need to add to its size to use one.
