Mounting Circulators on The Wall
hot_rod
hot_rod Member Posts: 26,645
some UniStrut with the rubber type clamps. This will minimize any noise to the wall.
hr
  • Bruce M
    Bruce M Member Posts: 166
    No pun intended but what are the advantages of mounting circulators and check valves on the wall? What is the best way to do that and what is the best mounting material? Should it be done in copper or black pipe?
  • Norm Harvey
    Norm Harvey Member Posts: 684
    It can often be fabricated in a shop and then the board can be hung quickly at the jobsite. It keeps potential leaks away from the boiler jacket. It looks impressive.
    The material can be anything, stained wood, painted wood, diamond plate,
    http://www.newcastleadornments.com/Manifold1.JPG
