Munchkin code F09
scout
Member Posts: 1
What does code F09 mean on a Munchkin contoller? I reset it and the main burner fires for a second then shuts off. This goes on for a couple of minutes before the fault light and F09 comes on.
F09
scout, do a search "F09" you will get an eye full...0 -
FO9 on the Munchkin Control is flame failure. Check for spark. Clean spark (if no spark) or rectifier probe (if fires and locks out). Also check for leaks from a cracked chamber. I have had a few cracked Munchkins that would fire untill the water vaporized, then would lockout.0
- 120 Geothermal
