Manifolds for Heatlink Tubing...Boilerpro
VIEGA NA.COM
  • Boilerpro_5
    Boilerpro_5 Member Posts: 407
    manifolds
    I recieved a call for completing the installation of a radiant floor system. Heatlink 1/2 inch oxygen barrier tubing is installed in the slab and I need to manifold and then install heating plant. I have reworked O-ringed plastic manifolds in the past due to extensive leakage, replacing them with copper. I was wondering if any of you have suggestions for good manifolds for this tubing.
    Boilerpro
  • kpc_2
    kpc_2 Member Posts: 1
    I ran into....
    the same issue w/ leaking o-ring manifold a year ago....I ended up using the Wirsbo old style manifolds...the compression nuts worked wll no problem....the copper would be fine too...kpc
    hot_rod Member Posts: 26,645
    I use copper manifolds
    with copper crimp rings on all of my systems regardless of tube brand.
    Watts Radiant and PHP are my two favorite. Alberta T Drill and Sioux Chief also have them available.
    I like at least one manifold to have Dahl mini ball valves.
    Between those four companies come virtually all the copper manifolds you see. Regardless of the name on the box :)
    hot rod Bob
