cast or malleable
Ken_40
Ken_40 Member Posts: 1,310
BM fittings a tad more expensive than CI. We also found the extra thick CI fittings had little to no chance of "flex."
The iron fittings are also less impacted by the water and O2 than CI - rust and corrosion-wise. Having replaced many old steamers, we found BM fittings rarely used, but when in place (usually a leak repair from more recent times) nearly closed with rust and scale after time. Not that CI doesn't rust as well, but the rate of corrosion sems very much to favor the less "active" CI over BM.
Having been in the biz for over 30 years, we also had the honor of replacing steamers we initially installed/replaced 30+ years ago. Thank god we never used BM fittings! We'd still be there sawzalling ells and tees.
Steam and CI were meant for each other IMO.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=504&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
