4 year old pinnacle boiler
Is it all the way around the exchanger? Or just that side?
  • Paul Rohrs_4
    Paul Rohrs_4 Member Posts: 466
    ANNUAL Service
    This boiler resides in our own shop. It IS serviced every year to include cleaning the combustion chamber.
    This is what Matt found this year after having it pristine from the previous year.
    Matt is musing about putting "A pinch between your cheek and gum" for that full hydronic pleasure.
    Anyone for a cup of Delta T or Hydronic Coffee?
    We can only surmise that it is business establishment located behind us that burns (apparently legal) substances in his solid fuel burning stove/furnace. It puts out quite a bit of smoke, much like Scott Milne.
    Regards,
    PR
    EDIT: This has been running without incident for 4 years and was set up with a combustion analyzer.
  • Weezbo
    Weezbo Member Posts: 6,231
    i have not seen
    the Peerless oil fired, however i would hope after a years operation that it would look cleaner than that... have you looked around the vents it seems strange to me that all these various condensing boilers seem to be Cleaning the Atmosphere rather than polluting it like our older boilers.:)
    maybe you can send the neighbours the bill . would the DOE love to have invented That new form of revenue:)
    i noticed in many of the major cities that there is definitely an air quality particulate acquisition during the day...so much so, that you can wash your hands and face come down the elevator, walk across the street take out a white handkerchief ,wipe your face and what looks like soot shows up on the handkerchief... i wonder if it is pollen or something along those lines though that causes the beginning of the process of this accumulation that has shown up on a few installs over the years...are you getting some of the new and improved nat gas in your area? maybe in this instance That might be the cause.
    well, thanks for sharing some insight...
    hot_rod Member Posts: 26,604
    LP or Nat?
  • Paul Rohrs_7
    Paul Rohrs_7 Member Posts: 173
    Nat Gas
    Matt did change out the blower. The seal was corrupted on the shaft with the impeller.
    All's well, it is still purring along.
    Paul
  • gerry gill
    gerry gill Member Posts: 3,083
    gwgillplumbingandheating.com
  • Paul Rohrs_7
    Our shop
    has a Plumbing division, HVAC division, and Radiant Division. I will service it weekly if needed just to keep the scorched air junkies off my back. Let's just let this be our little secret.
    Honestly, each year we have seen "Normal" accumulation, but this year must have been particulary abnormal.
    My only point is that modulating/condensing boilers need to be serviced. Period.
    Paul
  • marc
    marc Member Posts: 203
    Cleaning
    How do you clean the portion behind refractory? Just curious.
    Thanks, Marc
