Leaking Radiator Valve
Confused_6
Member Posts: 5
I'm a homeowner and have come across a radiator valve with a slight leak. The radiator is on the second floor of my home. I was wondering if someone would be able to view the attached pictures and provide me with some advice on how to handle the situation.
Also, is there a way to clean the valve so that it looks better than it does?
Thank you.
Thank you.
