Dual-Fuel Systems
boilers would be a better choice. The fire box and engineering for a solid fueled boiler is a bit different then a high efficiency boiler. Sticking a gas, oil, or lp burner in that area is often a compromise design. probably why you don't see a lot of them out there.ialong side the wood
I'd suggest a mod con as the back up to either a pellet or cord wood boiler.
Shop around, however. pellets are not all that cheap anymore. They seem to float around the same price a LP in my area. Corn or grain is a fairly localized fuel source and not really dependable from year to year.
Cord wood is still the best low cost fuel around here. But it takes some $$ to get a nice system installed and piped correctly.
Keep in mind the basic OWF outdoor wood furnace, runs aroud mid 40% efficiency. 60% of the woods energy goes up the stack. if you have to buy firewood this is not a great conversion.
Think solar with high efficiency back up :)
hot rod
hot rod
Multi-fuel boilers??
Anyone have any experiance with installing multi-fuel forced hot water boilers. A customer is looking for a new system that can burn either oil/wood pellets or gas/wood pellets. Building is approximately 3000FT2. Don't know where to begin. Any help would be greatly appreciated.
Thank You
Dan0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
