High-Efficiency Showcase (Dan H.)
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,687
under the Systems tab (above) called High-Efficiency Showcase. If you have a high-efficiency job that you'd like to show everyone, this is a good place to do it.
You can send me either a PDF, or a Word document with photos and I'll convert it to PDF for you.
These case studies should focus on how you took an old job and made it better, or how you planned a new job to be as efficient as possible.
Take as much space as you'd like. All are welcome. Thanks.
Retired and loving it.
