pressuretrol adjustment
Stuart Rogers
Member Posts: 51
The specs for the pa404a with additive differential are here:
http://tinyurl.com/35t5he
The diff available is 1 to 5 psi.
pressuretrol adjustments
Good morning
I have a honeywell PA 404a pressuretrol. It was set at .5 cut in with 1.5 diff.
I was trying to adjust the white differential wheel in the box however it stops at 1. is this the limit for this ?
Seems that I can only adust down to 1.5. cut in plus diff equal cut out.
One pipe system.
Thanks0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
