BEST THERMOSTAT
Al Letellier_9
Member Posts: 929
Can't use mercury stats anymore so digital is the way to go. Keep it simple. If you have outdoor reset a simple T87 round digital by Honeywell is all you need. With an old boiler, I wouldn't look at doing too much temperature setback as you would lose efficiency by setting back too far. 5 degrees max would be my recommendation. Again Honeywell makes a wide variety of stats and are your best bet for quality.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=522&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
BEST THERMOSTAT FOR HOT WATER BOILER
I have an old boiler (70+ years) Just got her running right - thank you Brad. I would like to know what you guys prefer in the way of a thermostat for hot water heating. (mercury type, dry contacts, or digital) any why you prefer that type.
John0 -
I have installed a digital one and the temp goes 1/2 degree above the set point before turning off, and below 1/2 degree before turning on. I was just wondering if this swing wastes for fuel than a conventional round stat? Or is it such a little difference that it will not matter.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
