munchkin outdoor reset
you would need to set the minimum temp on the reset curve to remain high enough to trigger the air coils.
and, unless you're doing high temp radiant, you need to mix down from the high temp zones for the radiant. That means either vision two, or additional third party controls typically.
  • chris_93
    chris_93 Member Posts: 84
    munchkin 199 w/ outdoor reset
    Hi I have a 199k btu munchkin boiler. it is used for four high temp zones with hot air coils and 4 zones of radiant (ceramic tile). Will the outdoor reset in the vision one kit lower the outlet temp., or will it produce a high temp setting and just modulate to keep producing the high temp.
    If it lowers the outlet temp w/ relation to the reset curve, how can I use it with the strap on aquastats for the blowers. Any help is appreciated.
