Tekmar 256 wiring
Roland_4
Member Posts: 84
Hi All, What type of wire will I need to connect the outdoor sensor to the 256? The run is about 60'. Do I need shielded or plain #18 twisted pair? Thanks, Roland
18-2 should be fine
Make a good tight connection. This is a thermistor you are hooking up to.0 -
Shielded
I have had problems with unshielded wire and Tekmar sensors, particularly with longer runs like this one. I would use shielded wire on all thermistors.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
