domestic water circulator placement
Brad White
Brad White Member Posts: 2,399
-Ernie White, my Dad
  • Georg
    Georg Member Posts: 8
    I just had a new heating system installed (Triangle Tube, prestige 175) with a smart 50 domestic water heat exchanger. The drawing in the manual does not agree with what has been installed.
    Here a drawing of what has been installed
    boiler------------------------------------pump-->boiler
    pump | pump |
    V | V |
    heat exchanger radiators
    Here a drawing of what the manual says:
    boiler-----------pump---------------------------->boiler
    pump pump | |
    | V | |
    | radiators |
    V |
    -------heat exchanger-------
    Does anybody know if this make any difference? Is any of these arrangements better than the other? Should I be concerned that the installer did not follow the manual?
  • Georg
    Nicer drawing
    My drawing looked so nice in the message window before submission.
    boiler------------------------------------pump-->boiler | | | | pump | pump | | | | | V | V | heat exchanger radiators
    boiler-----------pump---------------------------->boiler | | | | pump pump | | | | | | | V | | | radiators | V | -------heat exchanger-------
  • Georg
    Next and hopefully final try at drawing
    My drawings in the text window are obviously not working, here I am attaching the drawings.
    Here a drawing of what has been installed and of what is in the manual are attached.
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    I like the
    your second drawing where you are showing the indirect as your buffer tank in line with the primary loop. then it shows a space heating loop as a secondary loop. Classic primary/secondary type piping using the tank as the high temp load while either stepping down or injecting with the secondary loop.
    Rich K.
    Make Peace our Passion while Supporting our troops!
