Sizing 2 pipe steam systems
Unknown
Member
Just the radiation, and the piping and pick-up factor that is built into the steam output ratings on most manufacturers literature (so that you don't need to add it in).
Unless it is an old 2-pipe air vent (or Paul System), there are likely metering devices (special valves; OR orifices) on the inlet to each radiator, and these limited the steam volume to LESS than the radiators could condense.
Size to the radiators.
Noel
Noel
Does one take into account the return piping when there are no steam traps present . This is an old system where the return piping from each radiator drops into the condensate return located in basement . I'm trying to size this boiler properly . Any help would be appreciated.
Bob0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
