pressure relief orientation
curious_6
Member Posts: 1
As far as I can recall, all the 30psi boiler pressure relief valves I've come across have specified vertical installation. putting it directly in the boiler without any valves etc I can understand, but why must it be vertical? Somthing to do with sediment? I ask because I have a water heater being used as a buffer tank where I would like to replace the T&P valve in the side tapping with a 30psi pressure relief.
relief valve
Code requires that the safety valve be in the vertical position because some manufactures make safety valves that have a floating seat that could lodge sideways in the valve if it should happen to discharge from that position.0 -
I see...
There's usually a good reason for these things. Would it be kosher to put the valve in a side tapping with a short nipple and a 90 to make it vertical? Now it's on the top of the tank on a tee, but I'd really like to put an air vent there instead.0 -
are we talking...
about Pressure relif valves OR Temperature AND Pressure relif valves...big diff. I agree about PR valves upright. T&P valves must be totaly w/in the top 6" of the water heater tank...
pressure only
It is strictly a low temp buffer tank - the heating elements have been removed. I just mentioned a T&P valve since they can be installed horizontally.0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
