Gypcrete
troy_8
Member Posts: 109
1-1/2" Gypsum pour weighs approx. 14lbs/sq. ft. 3/4" plywood or osb is fine for a 16oc. subfloor.
Gypcrete
Does anyone know the load rate for a 1 1/2" gypcrete pour?
Also, is there any problem pouring over 3/4" OSB as opposed to 3/4" CDX Plywood?
Thanks,
Ray0 -
If my memory serves me well...
1-1/2" of gyp weighs 14.5 pounds per square foot. Check with the gyp people about OSB. Try these guys -- my experience with them has been very good, and they know their stuff:
http://www.hackerindustries.com
JMB0 -
Just had one poured .....
....and it does weigh 14 to 15 lbs per square. They now pour in just one 1.5" lift instead of two .75".
Gybcrete
When I did my house Ray, my general bumped up my floor trusses to the next sixe. 14" instead of 11". Same standard 3/4" OSB sub floor he uses on all his jobs. Gybcrete guys were fine with that and everything worked perfect!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 5.7K Gas Heating
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Job Opportunities
