Can someone help me with my aquastat dilema
Jason Quinn_2
Member Posts: 6
My husband and I just purchased a 3 flat bldg. but it doesn't have a thermostat. We want to keep the temperature in the units around 70 degrees. What temperature do I set the aquastat on to maintain 70 degrees. I don't want to make the mistake of turning up too high and end up with an outrageous gas bill.
Glenda- see previous post (nm)
-Ernie White, my Dad0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
