Through the wall gas heaters
Charles_9
Member Posts: 1
I HAVE A COMMERCIAL BUILDING, APPROX 13FTx13FT THAT HAS A GAS,THROUGH THE WALL HEATER. THERE IS NO WATER CONNECTED TO IT. IT IS CURRENTLY NOT WORKING. I NEED TO REPLACE IT OR REPAIR IT. I HAVE NO IDEA WHERE TO START. ANY HELP PLEASE CALL ME AT 516-521-5291.
Rinnai or Monitor
both have nice, efficient and modulating input/output units.
Start with a calculated heat loss rather than replace nameplate for nameplate. It will pay dividends.
It sounds like you are pressed for time but see what you can do. Check the Resources tab above under Heat Loss Calcs."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Charles, give me a call
at 401-437-0557. I tried your number and got no answer.0 -
Seriously? A 13' x 13' commercial building? If it's little more than an uninsulated tin shed in a cold climate, I'd suggest looking for a gas-fired radiant heater and hope that you can find one small enough...
Otherwise, why not just a strip of electric baseboard?0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
