Radiant Heat
Leo G_100
Member Posts: 7
My house has water heat with a gas fired boiler and cast iron radiators. I am remodelling the bathroom and am wondering if I can remove the radiator and replace it with in-floor radiant heat that would still be connected with the rest of the existing heating system in the house. I'm guessing it would be OK as long as I maintain the loop, with the water flowing through the in-floor pipes, then returning back and along to the next rad on the line. Any information/confirmation would be greatly appreciated.
Roth Mini Shunt
You can't use the water from the radiator directly, it is too hot. This product acts like a mini injection system with constant circulation. Relatively inexpensive and can be piped to your existing hot water system.
Hope this helps you.
Glenn0 -
someone has given you Bum Scoop...
that is not a coherent strategy.
You would be better off planning to go with a simple mix off boiler with an I series R 1/2" Taco zone valve with its own pinner circ...wait a couple months and the Wilo pinner circs are supposedly to be available.
Glenns idea is good too, it at least has some rational to the control issue...my buddy installed 4 or 5 of a similar item , in an antiquity renovation last year...0 -
Radiant Heat
Thanks for the info. That definately helps!0 -
Radiant loop
Staple up or in floor pex? How mush floor area?
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 977 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
