Cast Iron baseboard leak
Karl_6
Member Posts: 10
I have a leak in a radiator 30 (?) years old. Is there any way to repair it in my home? I am told high temperature silcone cement?
Karl
Karl
Where is the leak? Between sections? At the valve or return connections? A crack in a section?0 -
The crack is in the section toward the end. Not at the valve nor vent but not in the middle of the section either. I am going to dremel out a clean spot tonight toi see exactly where it originates--it is somewhat difficult to see the actual crack rather just note the steam and later, water drip. I tried a steel putty (name I forget by this point) but no dice.
Karl0 -
Karl
MY Opinion for whats its worth
It can be done but is very difficult and time consuming. Unless you have a radiator that due to size or looks can not be replaced I would opt for buying a replacement.
Scott
Hmmm....grind down the old surface "treatment" (paint)...then what??? I'd like to give it a try.
Karl0 -
radiator crack
Other than a thorough cleaning and grinding down to the bare metal, what is the best to use. I'd really like to see if I can save myself some added expenses..
Karl0 -
If you get it real clean PC-7 or J-B Weld, different brands of two part epoxy, might seal it. Worth a try.0 -
try a can of base hit0 -
Try This
Go to a boating store and buy "Marine tex".
It comes in white or gray.
EMPTY the baseboard first.
Prepare the crack as stated before.
Marine tex is the strongest epoxy product I have ever used.
Al
Have you ever used it on radiators I know my mechanic buddy uses it on gas tanks in cars and boats.0 -
steam radiator leak
Well, I ground down the area and then cleaned it off with acetone and then applied propoxy 20. It didn't stop the leak but slowed it down considerably. I reground the area and widened the cleaned spot and reapplied the propoxy 20. Now, I fired up the boiler last night and, so far, so good! I'll keep all of you posted as time goes on but I am cautiously hopeful. Thanks all
Karl0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
