help wih joist trac
wethead in wi
Member Posts: 10
i am doing my first joist trac job. just curious as to what you guys do when drilling the floor joists. I have 2x10s and have to drill the whole length of a 56 foot long house. any help would be appreciated. thanks
drilling holes
The only really easy way to do it is to let your helper drill them. It just has to be done, so get to it. A good drill and sharp drill bits make life easier. I've seen a laser advertized that goes in the first hole and sends a beam of light to the next joist and so on thru all the joists, making it easier to line them up. Can't find one yet, but when I do, I will own one.
Happy drilling !!!
i am running half inch tubing. whats size hole should i drill?0 -
Sharp bit, powerful motor
2" hole at least as you need to get two tubes or more thru the holes.
The B&D TimberWolf on high speed with a razor sharp bit is the way to go.
That Stabila hole alignment laser is very handy for that. I'll send mine up for you to try if you'd like.
www.stabila.com/main.taf?p=1,2,4,1
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
Thanks for the advice. tommorow i will be drilling the holes. let the wood chips fly0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
