psi loss
Ryan Wistisen
Member Posts: 1
In a tank type water heater what is the water psi loss? I have been searching all over the web and other sources and have not been able to find anything. If anyone knows the answer or has an equation that I could use that would be very helpful.
Piddling
The real losses through most tanks are borne by the inlet and outlet nozzle conditions. Cameron's Hydraulic Data has some figures for you. Naturally this is a function of flow and velocity and if the inlet is sharp or rounded/reamed.
Don't forget the drop tube either."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
The dip tube is [likely] the greatest source of loss as it's often somewhat smaller in diameter than the connection size. Even then, losses will likely be negligible in a typical residential system as I've never seen a tank water heater with smaller than 3/4" connections and a dip tube with [about] 5/8" internal diameter. A typical residence has a 5/8" meter, a 3/4" - 1" entrance and 1/2" - 3/4" main domestic piping. Until quite recently, both the domestic cold and domestic hot would be in 1/2". 3/4" for both has become common, but given that standard 5/8" meter it's almost pointless...
Again, in a well-designed system, the tank water heater will not add any appreciable pressure drop--that's why you're having a hard time finding--it's inconsequential to begin with...
- 167 Indoor-Air Quality
