JOT replacement in the kitchen ( Ron Jr. )
Darin Cook_5
Member Posts: 298
Lets make plans for you to come upstate. I will give you a wide open basement or garage and a blank 4' X 8' sheet of white tile board and let you go crazy with a pump panel. You are the king of cramped quarters! Great work, as always Ron.
Darin
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=509&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Darin
This was in Wantagh , NY
The customer is the original owner of this Levitt home , built in early 50s . The JOT replaced a Low York in the early 80s .
The floor radiant was still connected , but no bypass piping was used . They musta been hopping around the house if they were walking barefoot . I'm suprised the high temp water didn't cause any leaks for all these years .0 -
Peerless for a Peerless
This WBV3 is sized alot better for the home . 3 zones , 2 circs were at the boiler . Makes it kinda tough to squeeze in everything . Which is why you see the circ housings facing down . The boiler cover just cleared the top of the higher circ . We added a bypass for the radiant zone too .0 -
Great Job Ron,
as per usual! I hate really tight spaces, but you always make it look easy.
Dave0 -
Ron,
Any flue pipe involved here? I imagine you've got a baromrtric built into the chimney,? OOPS...there it is. I didn't know that this boiler has a center/top flue option. (dopey me!)
Looks easier than some of the closet installs you do. Nice job Bud. Chris0 -
There's only one man to call...
When you need to put 10 lbs. of stuff in a 5 lb. sack.
Ron Jr!
Outstanding work.
Thanks buddy
On paper , these jobs are a piece of cake . They're right in the kitchen , about 10 steps away from the work truck . Every pipe to reconnect is less than a foot .
Reality is I go home from these jobs more exhausted than when we hump out a steamer . You try to pipe it out sitting on a bucket and wind up doing most of the job on your knees . I assembled the new one while Sal ripped out the old . I had to take apart the supply piping 2 times to get it right . But now we know how to do these jobs to fit 2 circs under the cover .
Thanks Ken .0 -
Speaking of a prefab
I'm going to prefab a whole manifold to fit in my own boiler cubby hole under the stairs . Probably 3' by 6' , I'm gonna try to mount 4 circs or zone valves , a return manifold , airscoop , PRV , Extrol , a multizone relay and an outdoor reset control . So when I decide to upgrade my boiler , it'll be just 2 pipes to connect . Sounds like a pipedream though when I think about it .
That'd be a blast working side by side with you , Darin . I was born upstate in Ticonderoga . I'd love to go up and check it out and see if anything's changed since I was pooping my diapers and liking it .0 -
Thanks Dave
Usually Sal jumps right in and pipes everything in the front . But this system was too busy with crazy piping , and it was Friday ........ I took the reins . We have another bad batch of 3/4 " pipe . You have to hammer it into each fitting . On this boiler you couldn't get a good swing for any of the fittings . It was a pretty frustrating day .0 -
Chris
We tried to hide the placement of the barometric . Your eyes are too good
For the record , I do not like piping the barometric this way . But there just ain't no other option . It's either the run of a tee or none at all . I should check if Peerless requires one on every boiler . I know excessive draft is not a problem in these homes .
These jobs are the easiest of the 3 styles of Levitt boilers we work on . But man oh man do you walk out of these homes like you were repeatedly kicked by a mule .
Thanks alot Chris .0 -
hey ron have you ever had any problems with the lwco in that location getting airbound ? we have i see the air elim. not always dependable. nice stuff dude i always look forward to your posts/pics. mike.....0 -
Kitchen.
I feel for you and the service guys that have to squeeze a service call into those places.0 -
as always
Ron as always excellent job in the tighest of spaces ,truely a tight fitting maze of piping every thing all in the front and it all is square and levl nice work peace and good luck clammy0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
