Delayed fire from Steam boiler
thfurnitureguy_10
Member Posts: 1
My boiler guy is running into a delayed fire situation after changing the nozzle and cleaning the boiler. The burner will run for for 5 0r 6 secconds and with a "huff" it lights off. New spark box last year, Electrodes looked prety good, Chimney is big and not lined. We changed from a 4.5 GPH nozzle to a 4.0 at this years cleaning to reduce pressure cycling. Burnham V905A boiler, Beckett burner. Tech thought It was not getting enough air? Basement is vented to fresh air. Any ideas? thanks T.
Has he tested the unit using the proper instruments? What is the CO2, CO, Excess air reading, smoke, draft? What's the pump pressure? Is the burner set to factory specs?
Lots of possibilities.0 -
delayed ignition
simple question??? if it ran fine before the cleaning, then it's something in the setup0 -
Beckett does not spec
a 4.00 nozzle on any of the V9 Boilers. There is a rather drastic air band change from the 904's 3.5 nozzle to the 905's 4.5 nozzle. Beckett's specs are on Burnham's Web Site. Might try for a happy medium.
Tom, call us
if they can't get it straightened out.
V9 Delayed Ignition
I would suspect that what might have changed would be the Breech Damper setting. This is a pressure fire boiler meaning the boiler operates under positive pressure over fire and through the boiler. What controls that is the fixing bolt position on the Breech Damper. If you have that too far or wide open, the over fire draft will now be negative and the ignition will try and occur too far off the head. I've been on enough of these installations to know that way too many technicians think boilers like this are supposed to operate with a -.02 Over-fire draft and the result is they play with or leave the Breech Damper wide open.
Glenn Stanton
Manager of Technical Development
Burnham Hydronics
U.S. Boiler Co., Inc.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
