Main vents
Brad White
Brad White Member Posts: 2,399
from a slug of steam-propelled water crashing up inside the vent and making scrap metal of it's delicate insides...
If you keep that in mind, (as I think you are) you can do the right thing.
I have seen it recommended to put an elbow or two between the vent and the main, (maybe a switch-back with it's own dead-end tee, thinking out loud?) and slow down the wave at least.
But with that approach, there are no guarantees. You really do want a wave, if it occurs, to pass harmlessly by, below your vent tapping. One whack at over 3 PSI is all it takes. Even lower pressures can generate some force above that with velocity and a good slug of water.
-Ernie White, my Dad
