Digital Hot Water Thermometers
JethroMD
JethroMD Member Posts: 1
I am building a solar hot water system to feed into my conventional hot water tank and I need to install thermometers to monitor how the system is performing. Does anyone know of reliable digital thermometers that will work remotely so I don't have to keep going out on the roof?
Thanks in advance,
j
  • Brad White
    Brad White Member Posts: 2,399
    Azel Technologies
    has a simple thermistor-based two-channel digital thermometer for about $75 last I checked. Great to compare two points. I would instrument your system from the inside though, regardless. Just the idea of going out on a roof to see something and all...
    -Ernie White, my Dad
  • Andrew Hagen_2
    Andrew Hagen_2 Member Posts: 236
    Source temp
    Your differential temperature controller should also have a collector (source) temperature readout.
    A couple analog thermometers in wells on either side of the storage tank and a rotometer will tell you a lot about what the system is doing at any point in time.
  • Paul Pollets
    Paul Pollets Member Posts: 3,669
    Weiss
    Weiss makes a very cool soalr digital thermometer with either a 1/2" or 3/4" well. About $150.00
  • Weiss
    The Weiss unit is nice but if you pay over $70 each, you paid too much. 12 at time they cost me $56 each. Not just for outside use, with good lighting or a flashlight they work excellent in a boiler room.
  • tim smith
    tim smith Member Posts: 2,875
  • Uni R_2
    Uni R_2 Member Posts: 589
    ourcoolhouse
    If you want to log it and monitor it from anywhere, I'd go for this... Constantine could better comment on the suitability of this solution - not cheap at just over $500 IIRC, but it has the flexibility to monitor easily anywhere you want so you can know what's happening, even if you aren't there... and no piping requirements if you use contact sensors.
    http://www.ourcoolhouse.com/monitor/monitor.htm
