Air in cold water
Jon_10
Jon_10 Member Posts: 47
In the morning while running the cold water for brushing teeth, noticed air spitting out of facuet. I'm on a municipal water system and do not have a backflow preventer in the main line, nor do I have any bladder tanks for pressure control. Any idea where and why I'm getting air in just the cold water? Hot water no problem.
  • Brad White
    Brad White Member Posts: 2,399
    Cold water holds
    more air in solution than hot water. Heating water releases air (you may get a small puff when opening your hot tap but it is not likely in solution in your water). Your aerator give your cold water a last swirl before you see it. Nothing to be concerned about.
    -Ernie White, my Dad
