pipe size & edr
Brad White
Member Posts: 2,399
I am assuming this is one-pipe steam?
Is the EDR SF served by each 2-inch main roughly equal? Does either one exceed the 386 number by much if at all?
I do not see a problem.
The header from which the 2-inch lines emanate should be larger than 2-inch. I would expect that to be at least 2-1/2" if not 3-inch size.
Not sure I grasp the issues you are concerned with, otherwise.
-Ernie White, my Dad
limitation of the main in a one pipe steam system
I am replacing my boiler and I have read in Dan's book that a 2" main's maximum capacity is 386 sq-ft of steam.
I need based on the radiator load 540 sq-ft. I have (2)mains coming from the header. Is the math 2 x 386 and therefore that is why my system can handle the 540 because each main will only have 270 sq-ft of steam in each main.
It makes sense to me! how about you all?
Dan0 -
your question answers mine
thanks
Dan0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
