condensate traps
steve_164
Member Posts: 10
Is there a formula to figure out the depth of condensate traps?
trap depth
What kind of trap are you referring to? Steam or AC condensate? What exactly are you looking for?
Are you talking about a thermal trap? Condensate traps are usually buckets, installed after radiation with drain down or fixed orifice which are installed the same except you have to size the orifice. I personally do not like the fixed orifice. I think that orifice traps are kind of a scam. I worked for a company that bought into it the fixed orifice theory at the time I started with them. They only changed out half their traps and the orifice people talked about how much better returns they where getting and no more wet radiation. I used a IR thermometer to show them that most of their buckets that where left where bad and that probably the ones changed to orifices where too. They also had a varying load that does not work well with fixed orifice traps0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
