Do you have a permit for that
Joe Billow_6
Member Posts: 69
I see stuff like this quite a bit. One guy made a OWB from two diesel tanks, said he had trouble welding it because of the diesel smoke. He told me you didn't need any damper control if you knew how much wood to put in. He called me because he swore that the 007 he replaced every week was defective. I explained that Taco did not make 007 steam pumps and that he should be licensed to operate a pressure vessel. He shut it down.
It takes all kinds
http://www.city-data.com/forum/maine/166686-diy-home-heat.html
This should be one of Siggys "Glich and Fix"0 -
Are those people still alive? Relief valve? Geeeeeeeeeeez!!! I was thinking about a giant magnifying glass suspended over my house, with a rope & pully system to adjust the heat...It would be safer than that!!!
TimJust a guy running some pipes.0 -
If...
If a house in Maine blows up, and there is no one there to hear it... does it make a sound?0 -
I wonder what the liner expansion of all that copper is a 500f0 -
I love the towel rack...
Youse guys
are brutal. I can see a relief valve on the left side, it still has the yellow tag on it. It looks like about 700 inches of copper so from room temp (70) to 500F it should expand just under 3 inches.0 -
At least he hasn't installed a gas conversion burner kit...maybe I should save him the next one I pull out....
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
