Relationship between Anticipator setting and gas valve current.
You should measure the gas valve operating current and then set the anticipator to that figure for at least an initial setting. Is this what you are asking?
Relationship between anticipator & current value.
What is the relationship between anticipator setting & gas valve current value?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
