how to pipe new bioler with high temp and radiant zones
Tilmon
Tilmon Member Posts: 12
Read "Advanced hydronic heating" if you want to know more. It contains all the info on plumbing, wiring and system design.
  • shawn laverty
    shawn laverty Member Posts: 42
    I am installing a new buderus g215 boiler. This boiler will be feeding 3 high temp zones and 2 stadler mixing stations with a stadler basic heating control.Also here will be a buderus 119gl storage tank. I would like to know the best way of piping this boiler.
    I am not sure how to exactly pipe primary secondary piping or if that is a good way. Also I am not too sure about just a basic feed and return system tying into the radiant mixing station if there is a special way or not. So if anyone has any advice or a diagram that would be helpful. Thank you in advance.
    shawn
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    piiping
    There are many ways to pipe a system like that, depending on what your intentions are. It is good that you recognize your lack of experience with this type of system. Your best bet...get in touch with your local Buderus rep...he has a vested interest in making sure his equipment is properly installed. He should be willing to help you out with your design. Together with your supplier, they should be more than willing to help out a guy who wants to learn to do things right.
