Hot water ssystem does not heat properly
Steamhead (in transit)
Member Posts: 6,688
of the boilers and some radiators and post them here. Once we see them we should be able to tell you more.
"Steamhead"
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
"Steamhead"
Hi,
I have installed in my home 2 Utica boilers which are 250MBTU output each. I believe they were installed in the early 80's and the original system was a gravity feed steam system before converting into hydronic heat. It appears that the supply and return was reversed from the original piping connection. How do I determine if there are a flow restrictions or check valves at the radiators which could be causing the lack of heat and very high energy bills?
Thanks0
- 120 Geothermal
