Been a long time since I did this... Electric WH as an indirect
Going to have a wood fired boiler and am using an existing electric WH as an indirect.
Am using a heat exchanger (of course!) but cannot remember how I did it before.
I can't remember... take water out of the bottom and return it into the hot side? Or into the cold side? (That doesn't make sense.)
I have done it and it worked well. Any help?
    hot_rod Member Posts: 27,979
    If you can find
    a Bradford White, many of their tanks have additional side taps to make the use of external HX very easy. AO Smith offers a tank with a plate HX mounted on the outside also.
    Or remove the drain cock and add a brass tee for the connect to the woodstove HX. And a tee at the top hot for the other side.
    Actually with a pumped flow on the hx connection points are not that critical. Cold enters the bottom of the tank, I pull from there.
    Or consider the Butler solar wand which screws into the top and doesn't require a circ.
    hot rod
