dissimilar metals and problems
Home Depot Employee
Member Posts: 329
I know wholesalers like to sell these for the margins, but that is not what the post is about.
Back in the day I used them when the job had room, mainly because of both purposes a Dielectric union serves. However it required more so when exposed to constant oxygen such as potable water systems when two dissimilar metals are connected.
Dissimilar metals and problems
The question I have is, When is a dielectric union needed to isolate dissimilar metals and when is it OK not to use them? Does closed/open loop system make a difference. For instance, Is it OK to install a copper MIP adapter into a BI fitting with no worry of trouble from corrosion in a hydronic system? Thanks for your help.0
- 129 Chimneys & Flues
