1 1/4\"dry returns to 1 1/4' wet returns
Brad White
Member Posts: 2,398
a wet return of a given size will move about twice the capacity of a dry return of the same size, but as Jim said, you have to know what the load is in the first place.
If it works now "sort of" then performance should improve. However the path in total only has the capacity of the most sluggish section. In other words, if half is left as a dry return, that will define the return rate.
Wet returns are prone to clogging over time given that they are the low points of a system where things tend to settle.
-Ernie White, my Dad
Dry returns to wet - does pipe size need to increase
can a 1 1/4" dry return be dropped to the floor and properly function as a 1 1/4" wet return? Does it need to be larger such as 1 1/2"?0 -
Returns
That is the load of the boiler & how many returns are there0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
