Baxi outdoor reset
Bob Forand
Member Posts: 305
The outdoor sensor will save you fuel. It modulates the water temp based on the outdoor temp. It is in the instruction manual how to install the sensor as well as set the curve and slope.Just be sure to place on a north wall or someplace that it won't see sunshine. Good luck...
Baxi outdoor reset
Hi, I'm having a Baxi Luna HT 330 installed and would like to know if having an outdoor reset installed will make a big difference with the efficiency of the system. Also can I install the reset myself or does it require a tech to reprogram the boiler to accept it. Thanks0
- 167 Indoor-Air Quality
