LAARS Mascot 330 Combi Heater
I have installed close to 50 Baxi units wich I understaand are the identical unit with a different name on it. They work really well! I'm convinced it's one of the better mod-cons on the market. Conversion is realitivly simple.
  • Dorsey Davis
    Dorsey Davis Member Posts: 14
    Does anybody out there have experience installing a LAARS Mascot heater? Looks real slick and the main question I have concerns the LP gas conversion. I'm about to jump into it and if anyone has a moment I'd appreciate a tip...Thanks, D
  • Joannie_14
    Joannie_14 Member Posts: 22
    Laars Mascot
    I know some folks here have used them, and I'll let them tell you what they think.
    I just wanted you to know that you can call 603-335-6300 from 8-5 eastern if you have questions about the product. Ask for Applications Engineering and you'll get Paul, Bill or me.
    If you have specific questions, you can post here, too. We try to help when we can with posts on the Wall.
    Joannie
    Laars Heating Systems
  • Bob Forand
    Bob Forand Member Posts: 305
    Conversion is easy
    Turn "V" screw 3-1/2 turns clockwise and it is set to LP. The job is not done though, final adjustment is made with combustion analyzer. Did you purchase the QAA73 with it ? You will need it to set a couple of parameters for propane, fan speed and mixtire ratio. They are in fact sold to LAARS by Baxi.
    hot_rod Member Posts: 27,945
    A fine piece
    of equipment.
    i installed that unit in my inlaws place. i was concerned about the ability to produce enough DHW. It has never been a problem even with two DHW faucets running together.
    Very easy to install with that bracket and manifold assembly. quiet running, also.
    hot rod
  • Tim_41
    Tim_41 Member Posts: 153
    Baxi
    I have one in my garage/apartment. 2 zones of radiant. Works well, I did make a few mistakes on the install but since coreccted them. The DHW combi really gives plenty of hot H2O. The renters have never complained. 1 guy however did change the shower head.why????? the flow rate was so little the baxi never fired. I put the other head on and it was fine.
