What's This?
FRANK_24
Member Posts: 80
...........the framing for a bird condo
nm0 -
Closer
nm0 -
Wood
pex tubing surport bracket or...
Wood with holes0 -
That's the one.
What's the pair? How are they mounted?0 -
Prints of \"Object 2\"
will be available for $35.
Would be a great jigsaw puzzle.0 -
Stair ballast holes???0 -
radiant tube alignment boards?
To guide the tubes onto the manifold.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
I think
they're radiant-ready joists.Retired and loving it.0 -
Yep! The two shorter pieces will be mounted on top of the bottom member of floor trusses. Not only do they guide 28 3/8" tubes into a very small area, but each tube can be neatly secured and the entire units can be slid to-and-fro for adjustment before being permanently attached to the truss members.
Main reason for the time/expense is insulation. This is that super-insulated, double-shelled home in Northern Maine. Literally a shell within a shell. Original heating plan was for forced air "panel heat" through the floors themselves.
The unheated (at present) basement needs at least R-30 in the ceiling, but there's only about 6'6" from the floor to the bottom of the trusses. Most practical way I see to insulate such is with loose-fill. This was the most reasonable way I saw to bring all those tubes down from such a ceiling.
The long object will be about a foot above the Watts "custom tubular" manifolds. Perfect 2" o.c. alignment and integral clamps.
The manifolds will be rather low to the floor (only about 3' above) to allow panel rads in the basement that are still completely above the drain level of the system.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
