Peerless Pinacle system design
J Stret
Member Posts: 1
Would a Peerless Pinnacle or equivalent work in a replacement situation as follows. Two story, single zone, cast iron radiator hot water system?
Yes
After doing a heatloss and calculating the radiation in BTU's out, you may consider out door reset. Primary/Secondary piping at the boiler, pumping away from the expansion tank on the system side, a properly sized circ. for the boiler loop and a dirt separator.0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
