Pool Heat Exchanger
Maynard
Member Posts: 74
Had MM Flow Control On A Pool Heat Exchanger That Would Not Make Except When I Moved Paddle manually.
The Pool Filter Was Running And I Was Getting Plenty Of Water Flow At Heat Exchanger. How Much Pressure Do You Need To Operate The Control? Is A Flow Control needed On This Application? Thanks.
If it's more than
five years old, it might have failed. As I remember, I had one with a perforated diaphragm.
As far as whether you need one or not, some installers like to prove adequate flow before they turn on the boiler.
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
