Cleaning a tankless coil
Steve_152
Member Posts: 26
i would try a sparco mixing valve & a flow restrictor on inlet side to coil, use restrictor rated 1/2 gallon smaller than coil, that should make big improvement.
The other day I installed a new tankless coil on a hot water boiler, after the old coil was failing to produce enough hot water. When I removed the old coil I noticed that the outside of the coil was covered with black crud that I was able to wipe away. I aways hear coils fail due to scale buildup on the inside, this coil looks like the problem was the outside of the coil.
I have other customers whose coils are failing and removing them is not a viable option. I am wondering if a boiler cleaner would remove this type of buildup and help restore the performance of the tankless coil.
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
