steam heat insulation
john Cockerill_2
Member Posts: 33
1. What kind of thermostat do you have?
2. What and how big BTU/hr is your boiler?
3. What is the pressure at the boiler when the boiler goes off on high pressure?
www.Exqheat.com
www.Exqheat.com
I have 3 steam radiators right in front of windows what can I use between between the radiator and window to keep heat in the room actually melted blinds alot of lost heat out the windows and I turn the tstat down to 60 when not home and 68 when I am should I only turn back to 65 instead does it use more gas to heat the difference from 60 to 68 verses only 3 degrees0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
